OpenType features as invisible UX
Most readers never notice when typography is right. They only notice when reading feels like work. The features that decide which side of that line a font lands on are mostly the unglamorous ones — kerning, standard ligatures, contextual alternates — the parts that handle the friction the user never sees.
The features users never see¶
OpenType features get sold on the showy ones: swashes, discretionary ligatures, alternate numerals, fancy stylistic sets. Those are the ones that show up in marketing copy and design-blog round-ups. The serious typographic work happens in the boring features.
kern for kerning. liga for the default ligatures that fix collisions like fi and fl. calt for the contextual substitutions that keep cursive scripts from looking like they were typed by a machine. mark and mkmk for the diacritic positioning that keeps an ‘é’ vertically aligned across every base it sits on. None of those features are flashy. All of them are the difference between text that reads as text and text that reads as a series of characters.
Type Network frames it well: standard ligatures are a “font superpower” precisely because they turn a raw glyph set into a text system that behaves intelligently. The user never thinks about the fi ligature. They think about how the paragraph reads.
Kerning, the load-bearing feature¶
Of all the OpenType features, kerning carries the most weight in user perception. A poorly kerned font reads as cheap, because the eye notices the gaps before it notices the letters. A well-kerned font reads as professional, because the eye doesn’t notice anything at all.
Modern kerning is class-based. Rather than kerning every individual pair (the V/A cuts, the T/o tucks, the L/Y collisions), you group letters into classes — left-side diagonals, right-side diagonals, round shoulders, narrow stems — and kern at the class level. The result is a smaller table, faster lookups in the rendering engine, and consistency across accented variants you might otherwise forget to kern.
FontLab 8’s kerning panel handles the class structure natively. You tag a glyph as belonging to a class, define the class once, kern the class once, and every member of the class — including the eight Eastern European accented variants of the base glyph — gets the kerning applied. This matters most for languages with heavy accent coverage, where kerning every pair manually is the opposite of feasible.
Contextual alternates, the engine behind connected scripts¶
calt is the OpenType feature that decides which version of a glyph to substitute based on the surrounding context. Its native habitat is connected scripts — Arabic, Devanagari, cursive Latin, blackletter — where the entry stroke of one letter has to match the exit stroke of the previous one or the script falls apart visually.
Arabic is the demanding case. A single letter changes shape depending on whether it sits at the beginning, middle, or end of a word, or stands alone. The OpenType layout engine handles the positional substitution automatically through the init, medi, fina, and isol features. A handwriting font in any script may use thousands of contextual rules to vary glyph shapes so that the same letter never appears identically in a row, mimicking the natural variation of a human hand.
FontLab 8 generates the substitution syntax automatically when glyphs are named with the right conventions. A small-cap glyph named a.sc ends up in the smcp feature without anybody writing the feature code by hand. A swash glyph named A.swsh ends up in the swsh feature. The naming conventions are the schema; the feature code is the compiled output.
The messy reality¶
In practice, OpenType features do not always work as cleanly as the spec suggests. Discussion threads among type designers note that the OpenType specification recommends certain default behaviours but does not require them, and applications are free to ignore the recommendations. Firefox’s early OpenType support, in particular, made discretionary-ligature decisions that broke German words and Turkish dotted/dotless i distinctions because the engine ignored language-specific rules baked into the fonts.
This is why font engineers obsess over language system tags, feature ordering, and test strings. The user shouldn’t have to know that German wants Auflauf to behave differently from English office, only that both read correctly. The engineering work happens at the feature level so the user’s reading experience stays unbroken.
CSS, the application side¶
For web designers engaging these features, the CSS surface is straightforward in theory and messy in practice. High-level properties like font-variant-ligatures and font-kerning cover the common cases. The low-level escape hatch is font-feature-settings, which takes raw OpenType feature tags and lets you force a browser to obey your typographic will:
.body-text {
font-feature-settings: "kern" 1, "liga" 1, "calt" 1, "onum" 1;
font-variant-ligatures: contextual common-ligatures;
The trick is that some browsers respect the high-level properties and some require the low-level tags; in production code, you write both, in that order. Browsers favour the more specific declaration, which means the font-feature-settings line wins where it matters.
The moral¶
OpenType features are user experience for text. They are how a font behaves under pressure — long paragraphs, mixed scripts, accented characters, contextual letter combinations, language-specific rules. The features that decide whether the user has a good time are mostly the ones the user will never consciously notice. That is the point. Good UX, in any medium, is invisible until somebody removes it.
- Caring about OpenType features — Typekit Practice
- OpenType at work: standard ligatures — Type Network
- OpenType fonts — MDN
- Kerning and OpenType features in Firefox 3 — Ralf Herrmann
- Practical guide to alternate characters and OpenType features — Pangram Pangram
